Had a baxi solo 24 installed last week to replace my condemed glow worm. We kept the existing control panel and hallway thermostat as we are happy with how these work. However, since he left we have had the following problems:
1 Thermostat in the hall does not work/affect the boiler at all
2 Went to run a bath (as the timer should have been heating hot water) but there was no hot water. Checked the boiler and green power light was off. I clicked the heating switch on the wall control panel and the green light came on.
3 Following the issue at 2 above, the water did heat up, but the radiators also started to heat up, despite the fact that I had switched the heating off.
I have left a message for the engineer to come back and fix the problem. Any ideas - a simple cross wiring perhaps??
Thanks - Gazza
Thanks - Gazza
