New boiler
14 Jun 2009
Moray
Hi
Our boiler (Worcester highflow 3.5) needs replacing as the air duct has corroded and replacement is no longer available as I found out in my previous thread.
http://www.diynot.com/forums/viewtopic.php?p=1251978#1251978
Scottish Gas (sg) recommended the Worcester Greenstar 440 cdi. £4300 cash or £8200 on credit. Dont think we will be going with them.
Could anyone advise on a possible replacement?
It should be floor mounted.
Really looking for something reliable and reasonably priced.
What should the installation cost be around??
Thanks for all comments and sry if these questions have been asked before.
call 2 or 3 independent local rgis
they will be a lot less than bg
not a great deal of floor standers out there and they are more expensive than wall mounted
a local rgi will be your best bet
Worcester 550 and glow worm ultrapower 170 sxi are both direct floor mounted replacements with very good hw performance but not cheap. Avoid ****ish gas as they sub the work out anyway and are stupidly expensive with very poor customer service once you've signed on the dotted line.
Worcester 550 and glow worm ultrapower 170 sxi are both direct replacements with very good hw performance but not cheap. Avoid ****ish gas as they sub the work out anyway are are stupidly expensive.
no ones going to disagree b/g are a bit expensive but they don't always sub out work customer can always ask for direct labour if they want to.
there is no guarantee of direct labour even when you request it. Not that direct labour is any good anyway! Basically they are overpriced and have lousy customer service-search the net for millions of unhappy customers.
i question your maths, millions of unhappy customers, wouldn't they would be out of business, i agree there are some poor installers, mostly contractors..
There are approx 30 million households in the UK. Millions plural would be as little as 2million. How many have switched from bg to eon, southern electric, Npower, Powergen etc etc-more than 2 million. BG have lost market share to Homerserve amonst others too for repairs and servicing so I'd say my maths are spot on. I assume you work for ****ish gas?!
Thought so.
British Gas has had the most complaints to Watchdog of any company in Britain, including the out and out conmen.
Thank you for the replies.
Have a few locals coming in to provide estimates and weighing up these possible replacements:
Greenstar Highflow 440CDi
Glow worm Ultrapower 100SXI System Store Boiler Natural/LPG Gas
Vokera Linea Max HE High Efficiency Combination Boiler
Changing to a wall mounted boiler would provide a lot more options for boiler but would cause havoc with layout of kitchen.
Just gutted that a small duct can right off a boiler.
forget the Vokera option, they're not very good at all.
Hi
Why are you fixated on the idea that it should be floor mounted?
The modern design of boilers is targeted at wall mounted as all rooms have walls and that enables the most convenient fixing with the best access for servicing.
Very few manufacturers even produce floor mounted boilers not so if you are so blinkered you will be seriously reducing your options.
As always I would say take the advice of your chosen registered installer.
Tony
