If we did this, would the gutter need to be fixed to the lead too?Yes you could run gutter across the front edge , the existing will still need to be extended around the corner.
Stopping the water running over the edge making it run sideways should be fine .
Thanks for this. This type seems much better design.This is how rain water would be dealt with typically. View attachment 253068
I’ve just had another look, it’s really hard to take a photo of it, but it seems that there isn’t lead going up behind the roof tiles at the back of the dormer roof. Like there isn’t a visible upstand….on the attached photo it seems like maybe timber can be seen….The lead roof will extend up the roof slope under the tiles. There will not be anyway of fixing the gutter without going through the upstand
Employ a roofer good at leadwork to form a gutter at the front of the lead flat roof that drains into one or both gutters at the eaves. I expect any developer forced solution will be a bodge. It's not right but if there's not much else wrong with your new build its not so bad.
Thank you, I will take a lookThis is a good guide to leadwork but as mentioned some innovation from a good leadworker is what's required here or else it'll end up looking crap. https://www.associatedlead.co.uk/wp-content/uploads/2018/06/Guide-to-Rolled-Lead.pdf
I don't think you will find much to help in the leadwork guide it truly is a horrible detail as designed.
Making it look right is biggest challenge I think guttering of any description would look awful.
Either a leadburnt upstand round outside edges would work probably set back slightly to make it look like it's ment to be.
Or maybe a 60mm upstand say 100 mm in from edge of tiles to create in effect a gutter.
Either would want to be double thickness for strength maybe even introduce a stainless steel angle in it so it cannot get trampled down.
From a welding point of view easy job.
