Don't take any quotes for an unvented system until it can be proven that your mains can supply a lot more than 9L/Min. Wasting your money if that is the max and don't let anyone tell you any different.
You need a proper test on the mains performed at an unfettered outlet as close to the mains entry as possible (as @muggles mentioned - say at an outside tap) that will give you an actual dynamic mains pressure and flow, you can't make any educated decisions until that is determined. Did the water supplier not give you a report as to the mains capability when it was upgraded?
