- Joined
- 25 May 2010
- Messages
- 3
- Reaction score
- 0
- Country
Big question
I have an old 3-bed but quite large terraced house, one (only) bathroom upstairs, front right, with the kitchen as far away as it's possible to get at the rear left, in an extension. The current open-vent system is Oooooold. Museum-piece but reliable Kingfisher CF60 in the kitchen, only fails when the draw through the 22' flue dies in cold calm weather (I'm serious) and the pilot light snuffs out. There's an ancient tank in the under-stairs cupboard. With a tortuous 14m pipe run to the bathroom (a good deal of which I think is 22mm) and 7m to the kitchen. The hot water flow rates are so poor that I open the bath tap when I get out of the (electric) shower so that by the time I'm dry there's hot water for a shave. Boiler output just about (surprisingly) OK as house was fine this winter.
There's stacks of room in the loft, where I could arrange a compromise spot for the new boiler/tank, and that would give about 10m pipe to the bath and 12 m to the kitchen. I can easily get the gas up there, and with a flat roof the flue exit isn't a problem.
I'm resistant to the idea of a combi having hated them in previous houses, I really resent the cycling every time you open the hot tap (yes, there's lots of messy hot water on/off stuff in the kitchen, no dishwasher!).
Requirements:
1: mains pressure DHW
2: Acceptable lag from tap opening to hot water coming out
3: facility to ditch electric shower and install one using DHW system
So my questions are:
Is the length of pipe runs I've mentioned OK/Typical/sensible
(10m of 15mm holds 1.5 litres or thereby?) enough to make the compromise tank location work for bath and kitchen?
Would anyone recommend thermal store against an un-vented cylinder
Should I give up the compromise attempt and optimise the Bathroom/CH with a combi, and just put a separate instant water heater in for the kitchen?
Thanks in advance
J
Requirements:
Thanks in advance
J
