Hi all,
I have fitted a few of these in my time, but this one is giving me a real headache.
When it's flushed water pours out of the join between the pan and the cistern, now I've had this before and usually with a bit of fettling they seal, but in this case I can't get it to, despite at least a dozen attempts at dismantling/refitting.
I have tried the original foam type seal, done the nuts up tight, and not so tight, I've even bought a rubber seal and done the same, but whatever I try the water still pours out the join.
I can see no reason on either the pan or the cistern as to why they should not seal.
Anyone else had this problem, or come up with an easy way to get these things to seel.
It's a B&Q "Barcelona" WC, with SIAMP Monaco dual flush valve.
Any help/suggestions would be greatly appreciated. Thanks
