When you say that you test N-N and L-L between circuits, do you only do this for lighting circuits, or for all circuits? If the latter, it could be pretty tedious and time-consuming. For example, with an 8-way board, there would be 28 N-N pairs and 28 L-L pairs to test - a total of 56 tests!
But you don't have to test every pair. You only have to test each wire against all the others.
So assuming you have intact fuses or circuit breakers closed,
with the main switch open, connect one meter probe to the L busbar. Open MCB/remove fuse (or remove circuit 1 L from its fuse) and connect probe to load side of fuseholder (or circuit wire). Test then restore connection. Repeat with circuits 2-8.
Then repeat for the Ns removing one wire at a time from the N busbar and test.
That's eight tests for the L and eight tests for the N.
If you get a 'share' between one circuit and busbar you should also get a 'share' between the corresponding circuit and busbar, so those sixteen tests will identify one L-L or a N-N bridge. Only if you get more than two 'shares' do you have to probe the circuit pairs individually to find which circuit shares with which (and you only have to test the affected circuits, not all of them).
To identify an L on one circuit returning as a N on another circuit (typical stair lights borrowed neutral) remove the neutrals from the N busbar and connect into the corresponding circuit fuses. Then repeat the tests, testing between the busbar and the L+N pair. (Ensure all lights are switched on, and that tester will show continuity through the lamps.)
If you don't have an intact consumer unit or if the Ns aren't long enough to stretch into the fuses, then a test lead of a chain of crocodile clips makes quick work of commoning the circuits and disconnecting the one under test. (This would not be GS38 compliant and should not be used for live testing or insulation testing).
