New decking treatment
6 Jun 2011
Hertfordshire
I have just built the frame for a raised decking area and am ready to put the boards on.... the boards are 150mm treated softwood from a local timber yard. Was after a bit of advice... I am going to treat the ends with end grain preserver, the tins say it is green, can't find one that says clear? Will it stain it green?
Reading other threads it would seem that decking oil is the best bet? How long does the decking need to be down before treating it with the oil? Are the 'oils' much he same, ie is the Screwfix No Nonense one any good, someone has given me a brand new tin unopened and will use it unless advised otherwise!!
Thanks in advance for any answers/help, it's my first attempt at decking, so any advice is appreciated.
21 Aug 2007
Surrey
It sounds like it will stain green if that's what the tin says!
I always use creocote (creosote substitute) which comes in either light or dark. Others swear by decking oil.
Treat cut ends as soon after they're cut as you can, assuming they're dry, and you can apply the decking treatment whenever you like. I do mine once a year.
If you have some treatment already I'd apply a bit to some offcuts and see what you thin k of it.
15 Nov 2009
Sheffield
so they are tanalised, so using green endgrain preserver will coat the end grain in the same stuff thats on the face so will dry same colour
if you was to use clear you will see a green board with white wood ends
6 Jun 2011
Hertfordshire
cheers speed... i'll make sure i treat the ends.. would you recommend using oil straight away or leaving it for a while first and oiling it at the end of the the summer say?
15 Nov 2009
Sheffield
i personly wait at leased a few weeks
the timber is usually moist whilst its stacked in the timber yard so letting it dry will allow oil to soak in better
