I want to replace the side door in our house. The existing door is a UPVC unit thats been really badly installed, is very old and pretty knackered.
I want to replace it with a composite door, so today i pulled the fascias off to try and measure up the size for the new door.
The installation of the existing door is a complete mess. They've screwed timber strapping to the sides of the UPVC frame, sat the whole thing up against the back edge of the original door jamb, then screwed the strapping into the door jamb. Then covered up the visible jamb mess on the outside with PVC sheet.
Some pics, outside:
https://www.dropbox.com/s/3uh7qx68vbzvqbv/2015-08-03 17.26.00.jpg?dl=0
https://www.dropbox.com/s/q90aapn81dktefd/2015-08-03 17.26.07.jpg?dl=0
https://www.dropbox.com/s/w0rws65c44pesiz/2015-08-03 17.31.51.jpg?dl=0
Inside:
https://www.dropbox.com/s/ug3lwvmvw98fatu/2015-08-03 17.32.27.jpg?dl=0
Clearly that all needs to come out, the timber is also rotten at the bottom, but i dont know what i'd expect to find once i remove it?
should i simply measure up the opening in the brickwork, and get the new door made to fit that, and rip out all the existing timber?
Or should i expect to have to remove that timber, then replace it with new timber and thus the door needs to be made smaller than the brick opening.
The door seems to be attached to the inner leaf of the brickwork, so the existing door jam may be acting as a cavity closer? If i remove it i'm going to end up with a gap?
Any advice would be appreciated!
Cheers
Kev
Some pics, outside:
Inside:
Cheers
Kev
