Hello.
Finally getting round to putting a door between our internal garage and hallway. The wall is single thickness 100mm aerated block, and I think load bearing as joists from two directions, start & finish above the wall. There is no 1st floor wall above the wall I need to make a hole in.
Am I right in guessing a concrete lintel 100mm x 65mm would be OK to use in this situation?
Cheers
Cheers
