Hi all, new to the forum but have been a lurker for a while. I have a problem that I thought I'd put to you guys first before calling in a local sparky to see if I'm missing something.
I've recently tried to replace a light fitting in my lounge downstairs...here is a pic of the old fitting wired up:
I've wired up the red as live, black as neutral and copper as earth to the new light fitting shown below:
Problem is as soon as I connect the last wire in the new fitting the upstairs circuit trips? When the old fitting is replaced everything works fine. I thought the new fitting could be faulty but I've had this changed and the same problem persists. Could it be the wires sticking out the ceiling are tripping somehow? With the old fitting wired up it seems ok but it does trip very rarely. The new fitting causes the circuit to trip as soon as its connect and even before I put power through the circuit and try to switch it on.
Also, I'm replacing a fitting with one bulb to a fitting with 4, but the tripping upstairs circuit is still there when I try to fit the new 4 bulb fitting with only one bulb in.
Any help will be much appreciated.
Mike
Mike
