- Joined
- 17 Apr 2004
- Messages
- 40
- Reaction score
- 1
- Country
Evening,
Hopefully someone can point me in the right direction. Replaced the cloakroom extractor time fan today and added an isolator. All other wiring is existing and nothing else was changed but something is wrong.
Light switch ON + fan ON - works ok
Light switch off fan stays on timer, but light stays on, but only dim plus timer does not stop fan. fan continues to run.
Wiring is as follows...
Cable from CU to junction box. Splits to the light switch, plus a mirror then continues to next light.
At light switch COM = live from JB + Perm live to fan isolator. L1 = switched live to light fitting + switched live to fan isolator
At fan isolator L1 = switched live L2 = permanent live N = neutral all coming from light switch then same again from isolator to fan.
Cable from fan to isolator to switch is 3C&E. Black with brown sleeve = Switched live. Brown = Live, Earth and Grey with blue sleeve = Neutral.
All neturals at light switch connected to a WAGO connector.
Is there anything wrong with this as it seems to me that a live and switched live might be back to front?
Thanks.
Thanks.
