Wanting to put some sort of wooden flooring in a an old flat.
I am getting a bit overwhelmed with all the different options out there.
Here is the situation:
First floor flat with original wooden floorboards. 2 rooms and small hallway to be done. Rooms have had skirting boards removed to allow the walls to be skimmed. Floors are reminiscent of the latest roller coaster at Alton Towers..
In one room there was a (thin.. 3/4mm) plywood floor nailed down - I guess in an attempt to stop squeaks (It failed).
What leveling options should I consider? Will thick underlay with a moderate thickness laminate/ wood floor on top work, or should I be considering thick ply wood?
I have already screwed down the original boards that I thought were squeaky - which I was worried about by adding lots of plywood.
