new garage
10 Mar 2013
Durham
in the process of replacing exsisting lean to garage with a larger one 18ft long and 15ft wide at the planning and building regs stage at the moment thinking of a full concrete base and a steel framework with cladding on the walls and roof
with the base down the garage in theory could be erected in a weekend
my thinking is box section frame at both ends and one or two inbetween with purlins in between to attach tne cladding
one side will be seen by the neighbours if they did not like the cladding could it be covered with shiplap
Have you got planning permission for it? They may require the materials to be similar to those of the house.
no planning as yet just weighing options up only to be used for classic car storage so needs no frills
Yes, I don't see why not.
I think a we bit of thought as to how you could make the swap from metal to timber cladding time and cost effective, would be time well spent...pinenot :)
Why would it be favorable to go for shiplap? Higher maintenance, slower to erect...
I'm on the fence between plasti coated steel and shiplap for my garage build at the moment, but it will be insulated and internally lined as well.
Why go for the 'industrial unit with a sprinkle of shed', when you could have a masonry structure that actually may look nice and look as if belongs there?
Anything metal (internally) will drip condensation like a tap unless you build to a decent spec. Build quick and cheap, i.e. tin shack and you're likely to be disappointed with the outcome. You may as well have a pop-up gazebo.
Hilarious.
