hi ive just moved to a new house (to us) built in early 80s it currently has a microbore system with both pipes going to the same side on the rads.
im a sparky and am very hands on and would like ro replace the heating as we plan on being here until we retire, (not doing the gas or boiler itself dont worry) the whole house is a renovation project and the rewire starts next week.
i plan on removing the boiler and tank as i need the space in the kitchen and where the tank is will be stairs to the loft, do i plan to fit a combi in the loft.
my thoughts were to run 22mm plastic pipe from the boiler round the 1st floor outer edge of the building and T up and down in plastic microbore (1 rad per T off the 22mm) i could even use 15mm upstairs.
my thoughts on the microbore for the downstairs is i want it flush with no boxing in and some rads seem awkward to get to and i also like that the pipework is hidden, i have read there can be problems with this but it seems ok what we have now,
should it be 22mm for the hot and cold water also then down to 15?
many thanks yes im a novice but im trying to do as much as i can on my small budget
below is my floorplan and the red shows the current rads and the blue is where the boiler will be in the loft, could someone in the know mark out my 22mm run and manifolds possibly,
