Brave of you to just change the plate. Most engineers would change the complete valve to be able to give a warranty and peace of mind. Did the plate come with a new ball and spindle? If you used the old one then it may well be the O-ring that has perished or damaged on removal. Best. Ernesto
Yes, new ball & o-ring but the ball & shaft sits inside the o-ring. So if that was damaged or unseated, the leak would be between the plates. This is actually flowing out of the plate where the motor shaft exits.
