I’m just about to re pipe my house which is undergoing refurbishment. I’ve had a new heating system installed but have decided to install new pipework to kitchen and bathrooms as the old stuff is ancient, badly corroded (V. hard water) and a mix of imperial and metric fittings. I’m going to start from fresh and use a new route before plasterers come in. I’m planning on using plastic instead of copper. The cold water is fed from a borehole at 5 bar max. The hot is fed from a pressurised cylinder (heat pump) at 3 bar. Do I need to use 22mm on the hot supply and tee off in 15mm to appliances (apart from the bath) or 15mm everywhere? I’m running the supply to kitchen, main bathroom, en-suite, downstairs cloakroom and utility room (2 showers, 1 bath, 1 kitchen sink, 3 wash hand basins and 3 WC’s).
I’m trying to avoid pressure balancing issues. None of the showers are electric.
Cheers.
Cheers.
