Re-doing a bathroom with combi boiler installed already.
The hot bath tap is supplied by 22m pipe, this then splits with a Tee to 15mm to go to the basin hot.
The cold bath is 15mm and so is the cold basin.
I have a couple questions:
1: Is the bath hot supply 22mm for a reason? I'm replacing the taps and moving the bath so the pipework will be changed, do I still need to keep the supply to the bath hot tap 22m or can I safely use 15mm and 15mm to 3/4" tap connectors?
2: I'm also installing a manual mixer shower. Is it fine to use 15mm runs to it or should again the hot be 22mm?
