Hi All
This is my first post so please go easy.
I have recently bought a new house, we exchange in a few weeks time all being well. Its a semi, probably a bit larger than average semi with 4 floors and approx 4500 sq feet (roughly). It is currently centrally heated which consists of a very old boiler (Ideal Standard Concord 'C' 170 48.5kw) in the (semi) basement, a HW storage cylinder on one of the landings, system is vented and 2 tanks in loft. The system was installed in 1976 as I have the original paperwork and invoice (£1950!!) Sorry for all the questions but I have some thoughts on what I would like to do, hopefully you knowledgeable people can discuss whether these options are sensible / stupid or maybe put some other ideas out there before I get some quotes in a few weeks time
Clearly I need to replace the boiler, I would also like to have an un-vented HW cylinder as I have this in my current house and is excellent (dislike combi's in family homes).
The pipework is sensibly laid out, and the workmanship looks to be good - I would like to keep the pipework (with necessary adaptions for removal of header tanks and cylinder) and have a new, sealed system boiler and un-vented cylinder fitted where the current boiler is.
I have tried to attach a picture, hopefully that helps You can see the ground level out of the window (about 2/3 up the window is ground level) There is also a clay soil pipe entering and exiting the room from downstairs cloak room above.
- Boiler
Pipework
DHW
Regards
Richard.
- Boiler
Would it be possible for the condensate to discharge to the sewer pipe (clay) in the picture via a water less trap if boiler was high enough on wall? Otherwise I guess a pump is only option.
PRV discharge pipe, can this go up before going out or does it have to fall all the way?
Current circulating pump is separate from boiler and is huge! Would you recommend a system boiler with pump or heat only boiler and separate pump?
I have used the 'whole house boiler sizing guide' as linked to in various other posts and this gives a boiler size of 36.4kw. Does this sound about right (currently 48.5kw). It sounds about right to me and I appreciate that this is a how long is a piece of string type question as you do not know the property details.
Pipework
Is it sensible to use the existing pipework? It is old of course but it does look very sound, it takes a sensible route through the house so I see little point in replacing it. The main feed currently seems to be at least 28mm to and from boiler until the first branches come off then 22mm. Clearly it will need flushing. I intend to have the rads replaced so there will small amounts of re-config of 15mm pipework to accommodate new rad sizes
DHW
Ideally the un-vented cylinder would go in the basement next to the boiler as this is the 'boiler room'. I have looked on line and seen some horizontal cylinders which have PRV off the top. Cylinder could be built up high enough to allow PRV to fall to path outside. Any thoughts on this? I dont want a catch tank so if not possible to get the fall, cylinder could go in bathroom (2 floors directly above)
Regards
Richard.
