Hello people, I have a pressurised system with hot water tank and a Viessman boiler.I have 2 zones: Downstairs and Upstairs, both controlled by separate room thermostats.
Through basic investigation I've realised that there are two rads upstairs that are on the same 'plumbing' (forgive my terminology) as the downstairs rads.
They are in the upstairs hall where the room thermostat is located so not only am I getting a natural flow of heat traveling up through the landing, I'm also getting heat from the rads which are on the same line as the downstairs rads.
My problem is this, all the bedrooms stay cold as the thermostat gets up to temp before the bedroom rads barely come on, so I think to myself 'turn up the upstairs thermostat to compensate', all well and good until the bedrooms reach temp and then they get hotter and hotter because if doors are closed all the heat is trapped in the bedrooms.
So I'm thinking someone's cocked up the plumbing install until I go next door and their house is the same, builder says it's necessary to have at least one upstairs rad controlled by the downstairs thermostat. I reckon he's talking rubbish but need someone to set me straight if not.
Surely if all upstairs rads where controlled by the upstairs thermostat I wouldn't have to leave all the doors open to stop overheating as the entire 1st floor would heat up uniformly if balanced correctly.
Soz if I've overcomplicated this but in short:
1st floor thermostat not getting an accurate representation of the 1st floor temp because adversely affected by incorrectly plumbed nearby rads.
Any help appreciated
Andy
Andy
