I will start with a bit of back ground info. We have just moved in to a really nice 5 bed/5 en-suite property which started life as a bungalow with 3 beds on the lower floor.
It is set back from the road by around 40 yards and has recently had the roof space converted in to 2 more bedrooms complete with en-suites so 5 beds and 5 on-suites!
Wet Uponor UFH downstairs and 2 rads in the upstairs rooms which all work great.
There are 2 adults and 2 children in the family.
The problem is the hot water or should i say lack of it and possibly a flow issue.
The house is fitted with a Santon 150 indirect tank and what i assume to be a secondary circuit with bronze pump that runs continuously back in to the cold feed. Could this be effectively radiating the heat away and is it worth removing it?
I had originally thought the water softener may be restricting flow to the showers as none of them are that great, but even selecting bypass does not really improve matters, also the hot water doesn't last long. I could live with the flow but not the quantity.
I have checked the water pressure at the outside tap this afternoon and had 2.4 bar and i just need to confirm the flow rate (which i will try and do today)
I suspect it will be fairly low due to the distance the house is set back from the road (built behind another property)
If this is the case then i cannot see any options available that would improve quantity and flow. We don't have a loft so that's out.
A different Indirect cylinder would be in effect useless regarding flow even if i increased it's volume and from my research a large combi would not cope with 2 showers at the same time which would realistically be the max as we don't do communal washing.
I have asked for a few companies to check out what the situation is and provide options and costs but does anyone have any suggestions?
Sorry it is a bit of a long winded explanation of our issue! I have included a few pics of what i believe is the secondary. Most of the plumbing is poly just out of shot.
