Hi
We've just moved into our new house. We have a standard open central heating system (10 years ols) with a glowworm boiler, standard expansion and header tanks in the loft, central heating cylinder etc (that's about as technical as I get). When we moved in some radiators needed bleeding so that got done pretty quickly.
Basically we have reached the point now where when the CH is on there's no noise and everything is OK. If we then put the HW on as well after about 30 minutes there is the sound of air rushing through the pipes mainly starting at the pump and then going round the rest of the system. From reading posts I assume that the pump is sucking in air from the vent pipe as there are certainly no leaks anywhere else that I can discern. Why would it do this and how do I fix it?
I may well call a plumber out but also just want a general background on the potential problem so i don't get ripped off! thanks.
Any help would be greatly appreciated.
Jon
Jon
