New Internal wall
12 May 2007
I currently have 2 doors leading to my dining room from a lounge, i want to reduce this to one door or move the 2 doors over, reason being is i want to fit a TV in a certain corner but one of the doors is in the way, solution is to extend the internal wall that butts up to the existing door.
Question time
Would the building of the studwork frame and subsequent dry lining be done by a carpenter ?, would prefer to use one person for the job, he would need to make good the moving of the door frame as well. Is the job quite simple?
Yes. And if you get a good one he might be able to skim it as well.
in my humble opinion not a good idea
your rooms both sides may look imbalanced if you move your telly
why not just remove the arcatrave and board over the door behind the telly and find a bracket to support the telly but not in the door area
this will leave the door visible on the otherside and easily fully reinstatable
if you decide to go ahead you shoud be able to get a carpenter or builder to complete the full job :wink:
