New Motorised Valve fitted - Still no Heqating or Hot Water!
17 Dec 2009
Edinburgh
Hi can anybody help please?
New 3 port motorised valve fitted today, still no hot water or heating - old house will single boiler in shed outside - tank in cupboard in bedroom - can hear pump kickin when put on controls but no heat in pipes. I have bled all the radiators just in case and now it has started snowing!!!! :cry:
Please please any ideas?
Why did you have a new 3 port valve?
If the pumps kicking in, you need to check the wiring from the wiring centre to the boiler.
Is there any sign of live current at the boiler? eg a light on?
Check any fuses at the boiler as well.
see this every day, but if im wrong im sorry.
Blocked pipework where the cold feed tees into the return and vent.
Renew pipe there and system should run but if this works you badly need a power flush!!!
