Finally got a new phone with a decent camera in this time, so have a couple pics for you.
These are on the same site, a local B&B. Found during a PIR due to change of ownership.
Steel conduit not threaded and terminated correctly to socket - cables have chafed badly. Conduit earthed with BS951 clamp - not ideal. Spur not bushed to socket - and not even a grommet used. Basically a very poor attempt to provide power to the middle of the kitchen!
Wider shot was too dark, I have brightened it as best I can.
Two time clocks, feeding 3kw of panel heating each - No means of isolation for time clocks, and as you can see, the clocks went wrong at some point, and someone has fitted the ones below to fix it. Single insulated cables, covers glued, and basically very untidy. No attempt to keep the timers uniformly level etc, and the cables look ****e approching the timers.
