New plaster in bathroom
23 Feb 2008
I've just had a new bathroom put in including tiling and new plaster.
How long should I leave the plaster to dry given that it's my only bathroom and I have to use the shower so it is getting steamy everyday?
I will be using bathroom paint (assuming oil based) so should I prime the new plaster with PVA mix (5xPVA to 1xwater) or should I use emulsion primer?
Thank you
kt
It would be a very good idea to have an extractor fan fitted. It best to do this before finishing the decoration.
Otherwise instead of drying out, it will suffer from condensation, damp and mildew.
Don't use PVA under paint. The instructions on the paint tin will explain the mist coat.
Ditto JohnD - steer clear of PVA!
Drying depend on what sort of plastering you've had done, if its simply dry-lined you could start decorating next day, if its skimmed you're looking at a week and if its full depth on solid wall anything up to three weeks - I would imagine repeated steaming from your shower would extend these times.
You mention tiling, was this done straight onto damp plaster? Seems unlikely unless you've had cowboys in, makes me think more that you've got dry-lining in which case fire away.
