New Plasterboard and Plastering over existing wet joists
9 Nov 2005
Surrey
Hi
I would like to know what is best / normal practice for the following scenario.
A leaking flat roof of over 5 years + with water and damp penetriting interior ceiling.
Roof been re-felted and new insulation 75mm thich installed. The exisiting joists are wet. Some have been replaced.
I have been advised that we take the whole internal ceiling down. ( I agree ) and new plasterboard and plaster. I mentioned do they not need to dry out the joists first. I was informed they would dry out in time and it wouldn't matter.
My concern is if putting new pboard on wet joist then the damp will transfer into the p/board and new plaster and any paint that will be applied.
Logic tells me they should dry the joists first (Maybe with a de-humidifier assisting.)
Hope this is the right forum for this.
I wouldn't put any type of new plasterboard onto joists, that have had 5 years of being wet. Let them dry out first. Use the de-humidifier,, or let the fresh air/draught into the building to assist drying.
i may be wrong but if the joists are wet and damp they are going to shrink when they dry out and may crack the new ceiling
More to the point here lads, the fixings will prob rot away in the joists as they dry out. Sneeze near a drywall screw and leave it for any amount of time and it will rust.
Guys Thanks for the thoughts. You've flagged up some isdue i hadn't thpught of.
This is a great forum for hints tips snd advice
Keep it up
Pull down the ceiling and let the joists dry out, I doubt they will all be wet, it shouldn't take too long, now it's all in the dry.
