I have a Ideal Classic NF70 boiler which has been using a EP6000 electronic programmer since 1992 but unfortunately having run out of flat 48 volt relays to replace on the PCB it has to go.
Have now purchased a new Potterton EP2 programmer and have placed this on the original backplate assuming that it will do the same as the old EP6000?
The original set up was pumped with one Honeywell valve for HW and one Honeywell valve for CH which allowed hot water only and also central heating only if needed.
Now since fitting the new EP2 programmer whether it is set for linked or independent running I cannot get just the central heating to run without the hot water tank also being on?
My old EP6000 had the link on the back which had 10 or 16 programs set to 16 programmes that allowed just the CH on only. Can no longer get this set up with the new EP2 programmer?
Once the tank gets to the thermostat pre set temp of 60 degrees centigrade the central heating will straight away turn off until the airing cupboard copper tank drops below this temp then both will run again. Cannot run the CH only from the temp set on the main boiler.
Had set up the ID no on the EP2 programmer to “5” for the EP6002 independent setting without any luck plus tried the ID number “1” in a desperate attempt to get just the CH on only.
Is there something completely different with the old original EP6000 that is not mirrored in the new EP2 programmer.
Any help gratefully received as I am going round in circles to get this to run. Have I got a faulty EP2 programmer!
Classic Ideal NF70 gas boiler.
EP2 programmer that was a EP6000 (1992 Vintage)
2 standard Honeywell Valves 40003916-001 Powerhead
Honeywell thermostat attached to copper tank in airing cupboard.
Usual Grundfoss pump
