I have just had some rendering done (finished on 7th Nov), it is the lightwell down to the entrance to a basement flat. The work has been carried out using standard sand and cement.
I have read a lot of conflicting advice on how long to leave the render to dry, whether or not to use stablising solution or to apply a mist coat initially and if so how much this should be diluted by. PVA has also been mentioned in some posts I've seen on this forum and others.
I will be using white Dulux Weathershield as this is specified by the freeholder when giving consent for the work to be carried out.
Any advice much appreciated.
