new shower installation
18 Feb 2006
Birmingham
Hi all
need some advice. doing up the bathroom and need to install a cubicle, ive got about 760mm width and seen a tray that is 1200mm x 750mm. I know its close to the window but is that ok?
secondly, what type of shower should i install, at first i thought an electric one, but i want one that has a good pressure. I dont have a hot water cylinder or a cold water tank so will come striahgt off the combi boiler
If you have a combi boiler, you can just use a mixer shower because the pressure required is supplied by mains.
will this be better then an electric shower?
any links to a mixer shower
as has been said it depends, what comi have you got? (and post the power eg 24kw, 32 kw). some struggle some are more than adiquate. same with electric. electric costs more to run, but still works whilst your waiting for the plumber to fix the combi.
need to put a new combi in as well
how does a power shower work as ive heard a bit about them
not with a combi ;) ...they are pumped from a hot/ cold water storage cistern/cylinder...usually
cheers
will have to look into a thermostatic mixer shower
