Sorry if this has been already been asked but...
1) Am needing to re-route a couple of sockets (they're on a stud wall which is being removed) - but the only walls in the room then will be old lathe-and-plaster over sandstone.
Now my plan is to lift floorboards and run cables along the joist to the wall (not yet sure where they've come from), and then run them across the joists (drilling holes) until we're below where I want the socket.
But then what?
In other rooms in the house the sockets are the surface mounted ones, but don't look particularly good - my father suggests this is because it's not possible to fit recessed ones if its lathe & plaster - is he right? Am I really going to have to cut out the plaster to run the cable up the back and then reinstate?
2) If the existing cables aren't long enough whats best way of extending them - was planning to use a terminal block, tape it up well, and fix to side of joist?
But then what?
