Hello Guys,
I'm planning on adding 3 double sockets into the cupboard under the stairs for all my recharging needs and also 2 60w wall mounted spot lights (non earthed, wired together & plugged into one of the sockets). I've never done anything like this before so your help would be appreciated even if this means you telling me not to do it!!
On the other side of the wall (in the lounge) there is a single socket, I plan to drill through the wall behind this socket and tap the mains from there using the thick square grey twin & earth. Then into a fused switch (30 amp?) and then into the 3 double sockets in series.
Is that the correct way?
Am I allowed to do it as far as part P goes?
Do I need to have it inspected afterwards?
Your advice is always appreciated.
Pete.
Pete.
