New staircase painting/varnshing products?
16 Aug 2003
Hi all,
Ive just had my staircase replaced, i.e. spindles, handrails etc.
The style I am going for is wood finish on the handrail (maybe a medium oak) and then paint the spindles white.
I presume the best way would be to do the wood finish first and then paint the spindles to avoid the handrail soaking up white paint if i slip with my brush, which is inevitable!
Im pretty sure on the spindle painting procedure, knot, prime, undercoat and gloss.
Its the handrail im unsure of, theres lots of wood products available, oil, wax, varnish, rubbing with a cloth instead of a brush etc.
Has anyone any advice on suitable products and brands?
Cheers!
The order in which you do it is really what suits your skill level..alltohugh i would leave the handrail til last
If you do the bae rails etc first you will cover it in dust etc when you do the spindles...what about.....knot prime fill rub down and undercoat spindles..do one coat of stain/varnish on the bare wood, rub it down, gloss the spindles, second coat on the wood?
Tip for you...dont use a coloured woodstain like sadolin etc..all the intricate cuting in may leave loads of tramlines/streaks in the finish..
I use oil based wood DYE with about a third if oil based varnish in it...it stops all the dye soaking in to quick and lets go go much further too...put it on with a brush and then wipe over with a cean cotton rag
It will give you a far more even finish..and once you jhave rubbed it down, because of the varnish you mayonly have to give it one more coat.
Thanks for the help.
I ended up applying some oak danish oil to the pine wood and it looked great so i did the whole thing with the stain (saved me messing about with paint too phew). I ended up using 3 coats on the handrai and posts and 2 on the spindles.
I applied with a brush and rubbed it over with a cloth.
