New Stelrad Radiator
27 Jun 2009
Nottinghamshire
I'm got a radiator which needs swapping to match the rest in the house (stelrad) and whilst doing it I'd like to upgrade the output from this particular rad.
I had this one fitted and it measures 800 x 450:
I can get away with a 1000 x 450 to replace it but wondered which style setlrad to go for. I have quite a few P+ stelrads in the house and wondered what the output would be like compared to the one above. Or do you think I should go for a K2 to maximize the effect of it?
Thanks for your help
Google is your friend here! Google the rad and click on any sellers, the description should tell you BTU's. if you find the room not warm enough go for a k2
Thanks Jamesie.
I guess what I'm asking here is.... how will a P+ or K2 (800x450) compare to original one I've photographed (800x450) - Once I know this I'll know whether to simple up the size or whether a P+ or K2 will beat it in the same size.
The one on the pic looks like a K2 stelrad?? aint it?
p = one panel no fins
k1 = one panel one set of fins
p+ = two panels one set of fins
k2 = two panel two sets of fins
k3 = three panels three sets of fins
that looks like a stelrad elite k2
http://www.stelrad.com/uk/ try here for outputs
800x450 k2 = 1097w
800x450 p+ = 844w
800x500 k3 = 1645w
Brilliant, thanks for that.
Yeah the one I've photographed does look like a K2 but it's not in the same brand and I'm guessing it's fairly old - it came with he house.
As I want a bit more heat (BTU) from the replacement I think I'll go for 1000 x 450 (which means I'll gain an extra 200 x 450mm) and thsi will hopefully be enough.
The elite model looks like it has open sides and not boxed in (like the one I photographed - which is what you said). What are the softline and compact models? They both look boxed in and very similar don't they?
Thanks again
Thanks again
They are the same as the elite but with covers on Id say, the outputs I quoted you were for the compact range.
I would go for CenterRad radis half the price LITERALLY and very very similar to the boxed in compact range.
Plumb center own brand BUT made by Myson
http://www.plumbcenter.co.uk/en/hea...tributeValue1=CenterRad&sortType=&sortColumn=
Thanks for that. They are that much cheaper then?
I think I'll be buying a:
Stelrad Compact K2 450 x 1000mm (4678 BTU) £66.20 inc vat and delivery.
What would the alternative be in a CentreRad?
ooops yes they are a lot. Forgot you need a trade account for the best price on Center Rads
and thats a cracking price for a stelrad well done
