Hello. I need to run a supply from the farm main consumer unit via swa cable 39m length on the surface to a static caravan. I plan to feed via a 63 amp rcd. At the static end, Inplan to install 16mm earthing cable into earth rod. Can someone advise if this is safe and workable. Also, should I be earthing the cable armour? Many thanks.
