Further to my previous posts I've just spent an "enjoyable" weekend ripping out the old rads and pipework and replacing it with new. I have three rads connected, mostly via 22mm with 15mm feeds to the rads. The main feed / return pipes are capped until I have more time to install the remaining rads.
After bleeding the rads I managed to get all three glowing hot, however I notice that the Baxi Solo 60 still tends to cycle quickly, even though the roomstat is calling for heat. By this I mean it lights, runs for 60 - 120 seconds, stops running (boiler on light stays lit), then 2 - 5 mins later runs again.
I've tried all three speeds on the pump, and the fact that the rads are getting hot suggest that its working OK.
Is the boiler working correctly, or should it run continiuosly until the room stat or tank stat no longer calls for heat ? It has been suggested that the boiler PCB could be faulty, or could this be a faulty sensor that sits on the feed pipe sending wrong signals to the pcb ?
PS - you guys were right, the old pipes were sludged up and there was an airlock in the old system which was why I couldn't get the old rads warm ! - new rads are piping hot !
Malc
Malc
