I had a new Worcester Bosch 28i combi complete system fitted last August. The company made a pigs ear of the job though I did end up with a working system in the end.
During the recent cold spell I had to have the heating on 24/7 to realise 19 deg c in my lounge area, not wishing to maybe end up with a non working system I delayed calling in the installer to explain why until the worst of the weather is over.
I dont have a problem with the rest of the house heating as we all like our bedrooms on the cold side and the trv's work well for this. Hot water supply is fine.
The lounge is 36ft x 13ft with a large window south facing, the dining area has patio doors North facing and a large east facing window too. There is an unused fireplace in the lounge. Windows are double glazed and the cavity wall along the 36ft length is foam filled. Floor is concrete (non insulated)
There are 3 rads fitted, dining area is 600x800 double, mid lounge is 600x500 double and under the south facing window is a 400x1400 single.
Quickly looking at an online chart gives around 11800btu/h for all the rads.
All rads do have trv's fitted but are wound fully open. RF Room stat is in the lounge area set for 21 deg for this test.
6am with an outside temp of 6 deg and a room temp of 15 deg the stat was set to 21 deg and manual heating.
by 6:30 is was 16 deg, 7am was 17 deg, 7:30 was 17.5 deg and 8am still just 17.5 deg.
So just 1.5 deg raised in 2hrs. The trv's are staying open, I checked them. The boiler is not staying fired all the time which I believe is correct, once the return water reaches a certain temp I would expect it to cease heating until the return temp drops.
My original gas ch system had much bigger rads and didnt struggle like this one does, the installer suggested the rads now are much more efficient so can be downsized without a problem.
Thoughts please anyone....
