New Thumbturn Euro Lock Keeps Spinning From Outside
23 Jun 2014
Staffordshire
Just taken delivery of a brand new Yale 3 star thumbturn lock to replace the existing lock. Door seems to lock/open fine from the inside when using the thumb turn but if I step outside, close the door and put the key in the key just keeps turning and nothing locks.
If i take the barrel back out and hold it in my hand, the thumbturn and key both rotate together suggesting the barrel itself is ok? Which I would expect with it being new.
What else can I look for or what else could it be?
When I get chance I will test the old lock and see if the same happens with the key from outside - as we only usually use it from the inside so it may have been an old problem that i've now discovered.
Try it with the thumb turn in locked and unlocked position and see if it makes a difference
