Personally then if there's no jumpers on the back just take it back as faulty.Finally got an answer from Danfoss to my e-mail. They just sent me the User Guide! As if I hadn't already looked at that! My God, this is getting frustrating...
Well, to be fair to Danfoss, it's not actually quoted on their website, but maybe it was changed and suppliers didn't get the memo?. (To be fair, the fact that this copy is used on a number of websites suggests that it comes from Danfoss themselves, which is a bit of a whoopsy if it turns out to be wrong).
Yes. Basically the hot water on runs power to the boiler. The boiler gets hot and water gravitates to the cylinder. No wizardrySo should the central heating actually work as long as the hot water is on?
In dim past often the cylinder was near the back boiler and connection often was 28mm boiler to cylinder and coil in the cylinder was a few turns such that heated water in the boiler needed no mechanical propulsion to heat the waterYes, I did try turning up the thermostat to the highest temperature, without any effect. But surely the fact that the pump has kicked in is an indication that the system is responding to demand, but it's just not working right because the boiler isn't firing up? Presumably if it was the case that the room temperature was already high enough, the pump wouldn't run? (I think this is what @DP is saying, too).
YesI picked up a very cheap Drayton LP722 (£20 on eBay), and have replaced the Danfoss with this, having configured the dipswitch on the back to gravity instead of pumped, so theoretically all should work fine. One minor puzzle. In the manual there is this:
"On each side of the display there are four operating modes – one group for central heating, the other for hot water. "
But for some unfathomable reason it doesn't tell you which is which, either in the manual or via a label on the device itself. I'm kind of assuming that the left-hand ones are for the hot water, as that side is where the hot water boost button is. Can anyone familiar with the Drayton LP722 confirm this?
