New upvc ceiling
  • Thread starter Thread starter brian1104
  • Start date Start date
B
brian1104
Hi. I'm currently in the process of re vamping my bathroom. I'm planning on fitting a upvc ceiling as part of the re vamp. What down lights are suitable for these ceilings ie ip65,ip44, 240v,12v!!!! I'm planning to fit an extractor fan to deal with condensation. would this eliminate the chance of mould between the existing ceiling and new one? Any help would be appreciated.
The only downlights which will be suitable will be LED. Anything else will be too hot, and will discolour the plastic.
You should also select downlighters which can only accept LED lamps, to prevent people fitting halogen ones in the future.
The only way to prevent mould between the original ceiling and the plastic will be to ensure that the space is totally sealed from the bathroom - as in air tight. This will be extremely difficult, or even impossible.
What's wrong with a normal ceiling?
The ceiling was skimmed when we first moved in and painted. The light I fitted at the time plus a problem with the wiring in the house caused the light to overheat and this caused the plaster to crack. The house has been totally rewired so that problem is fixed.
Basically I have seen the upvc ceilings in other houses iv recently worked in and they look the part.... thought it would be the ideal way to brighten the place up without doing a full re fit.
Like you say.... it would be impossible to make the void air tight and I dnt want the problem with mould. I know it would be out of sight out of mind but It would worry me.
Would the extractor fan be sufficient to remove the moisture plus i was thinking as the bathroom ceiling is below the loft, would fitting air vents to create an air flow help
