I got a new combi boiler, Viessmann Vitodens 100 fitted at the end of October this year. The hot water takes around 75 seconds to reach a hot temperature in the kitchen.
The boiler is installed in a garage, which is directly joined on to the house and is fitted behind the kitchen wall. The pipes run upstairs to the airing cupboard, where the hot water tank used to be, and then back downstairs to the kitchen. However, this isn’t the main cause I don’t think.
The boiler is set on Eco mode and takes a minute or more to heat up to 60 degrees C, starting from around the 30 degrees C mark according to the reading on the boiler. Is this normal? It seems to start off slowly, before cranking up volume and coming on full.
Thanks in advance for your help. If you need more info then let me know.
