New Viessmann - Hot Water Takes Ages
Just double-check that you are in Comfort mode, and that your tap knob on the boiler is pointing at least to the dot, or higher. If it is still not working properly, call Viessmann Customer service.
It is in comfort mode and the dial is higher than the dot. I'll call Viessmann today.
Thanks for your help.
Would be interesting how you solved this problem? The same issue with may Viessmann heater. It is definitely not a piping fault. I have older Viessmann heater and it starts right after you tap the hot water. And it is working more then 10 years already. Is there any way how to solve this delayed hot water issue?
Very appreciate for help.
