Hi all - first time poster. I'll apologise now for my 'newbie' questions.
I've just bought my first property and am trying to get to grips with the CH system. Its a Potterton Puma 80e
I don't use the timer on the system, I just get the heating to come on and off by adjusting the thermostat.
I have a few questions that hopefully you guys will be able to help with:
1. When I crank up the stat to get the heating to come on it does for about 2-3 mins then it goes off again, then a minute or so later it comes on again and so on. It never seems to appear like its brought the room up to temp and switch off completely until it needs to come on again. Always on then off then on ... It heats the rads and water fine. Is this behaviour normal?!
2. The hot water seems to be very cloudy. Limescale? What can I do?
3. I have a normal 'turn the dial' stat in my main room (lounge / kitchen) which I find slips a lot so the dial will spin without actually moving the bits inside to turn the heating on. Can I swap this out for a digital stat? What should I look for and is it easy to fit?
Apologies for the long post. Thanks in advance for any help
