Morning,
I have read through these fourms and others till my Head is spinning and cant find an answer to my problem...
Here goes , Kitchen radiator freezing , just suddenly stopped last week,
So far i have :
1/ Taken it off and flushed it out with a hose , removing all the end caps till the water was clear.
2/ Done the " Bucket Test " Shut all the radiators off in the house , opened one of the dodgy radiator valves into a bucket and water came flowing out , did the same with the other end and that flowed well also, ran about half a bucket of water into the bucket from each end. Connected the radiator and filled it , the water coming out the pipes was hot as i had the heating on and it filled the radiator and for the period the heating was on it stayed hot. sadly when the heating went off and they rad cooled down it didnt heat up again when the heating came on.
all other radiators have been bled and work well.
3/ Checked water tank in loft and that is full and topping up the system well
4/ turned all rads in house off barr the dodgy one , whacked heating up and still didnt work.
5/ The rad does not have a TRV on it , not sure why as most of the others do. House is 9 years old and has the plastic pipes leading to the radiator.
I am at a loss as what to do next prior to getting a heating engineer in which i believe isnt cheap !! ( tight wad ).
All suggestions would be recieved with thanks.
Andy - Durham
So far i have :
Andy - Durham
