Often a bulb to bulb holder problem, this one...get someone to press the brake pedal when you waggle the bulb.
If no joy, try for 12v at the central pip carefully - if you short it out then a fuse pops.
If no 12v, then the cable, which passes through the tail gate grommets, has likely severed due to movement every time the tail gate is opened.
John
