- Joined
- 29 Jan 2014
- Messages
- 9
- Reaction score
- 0
- Country
hello. I wonder if you could be so nice as to throw some ideas my way. last night i went to use the cold tap and ome water came out but it got slower and slower and eventually stopped. it did the same with all my other cold water taps but i had plenty of hot water in all taps. i went to look at the pressure on my Megaflo Indirect Cylinder and it was at about 2 which should be fine. But then I noticed that the power switch to it was turned to the off position. It is one of those switches that looks like your average UK light switch on the wall. (you know you press it at the top or bottom and theres a red marking to idicate that its on). Anyway there is absolutely no way in hell that that switch was pressed by a person. It's almost as if it pressed it self. Which to me seems impossible? The cylinder and the mention switch are located behind a door that shuts solidly and I am the only one in the house at all times. Now I flipped the switch back to the on position and went to bed. When I got up this morning it is still on the on position and upon checking the cold water taps, some came out but again it trickled down to nothing within a minute and now it's all gone again. I am not sure what to do? Am I calling a plumber or an electrican? thanks for reading.
