Hi, newby here so go gently
Right......my intention is to fit a new bathroom suite and shower cubicle, so i've been busy removing the old tiles. Some tiles have came off ok, leaving only the tile adhesive, other have pulled off large bits of plaster.
I'm in an ex-local authority house, built probably mid 50's, and has cavity walls(not insulated if that matters).
Where large areas of topcoat? has came off, i'm left with a sort of rough powdery plaster probably 1/2" to 3/4" deep, though no bare brick is visable.
It looks like the odd bit of straw i can see in the plaster.
The max depth of plaster which has came off when removing the wall tiles is probably around 1/4", though in most areas it's only 1/8" or a few millimetres..
The walls were tiled halfway up,and will be again tiled halfway up, so i was going to plaster the section of wall where the tiles go myself, and get a proper plasterer in to do the area above the tiles, which will be seen.
Is it ok to use pva glue to 4 or 5 parts water to sort of seal the bare areas where the top coat has fell off?
I have made sure the remaining plaster is firmly bonded to the brick.
Also is it ok to use one coat plaster to fill the low areas up to the level of the existing plaster, before tiling?
By 'onecoat' plaster i'm meaning the pre-mixed stuff out of a tub.
Obviously it wont be seen,but will need a strong bond.
Also a question regarding the old tile adhesive,........does it get scraped off or sanded off, or is it ok to leave it on, as new tiles will be fitted over the top of it?
Cheers
Edit-
some pics added (hopefully)
Cheers
Edit-
