    Dismiss Notice
No Heating but still have Hot Water
Discussion in 'Plumbing and Central Heating' started by MazaB, 2 Dec 2019 at 10:58 PM.
  1. MazaB
    MazaB
    Monday
    6
    Thanks Received:
    Country:
    I have a Worcester Bosch Highflow 400 Boiler. On Saturday night my partner topped up the boiler from 0.5 to 1 & since we have had no heating but still have hot water. When I turn the thermostat on it is not calling for the heating - well the demand light doesn't come on. Can anyone advise please before I commit murder!
    (The pump is still running perfectly fine)
  2. ericmark
    ericmark
    27 Jan 2008
    14,375
    Thanks Received:
    1,275
    Llanfair Caereinion, Nr Welshpool
    Country:
    Have you followed the fault finding in the manual ? it lists three lights on/off, slow flash, fast flash, alternate flash and a chart showing likely fault.
    Google Worcester Bosch Highflow 400 installation instructions if you don't have them.
    • Thanks Thanks x 1
  3. MazaB
    MazaB
    Monday
    6
    Thanks Received:
    Country:
    Thank You for your prompt reply it's very much appreciated.
    I looked up the manual on Sunday but the boiler does not look like any of the diagrams it shows. I get that boilers change & faults are similar but it's states the fault with no green light is the control board would that stop the heating - the green demnd light comes on for 30 seconds but goes off & I don't see that within the faults in the manual.
  4. MazaB
    MazaB
    Monday
    6
    Thanks Received:
    Country:
    Finally found the right manual but it doesn't give details of fault finding
  5. muggles
    muggles
    28 Oct 2005
    10,961
    Thanks Received:
    2,141
    Oxfordshire
    Country:
    Can you post a link to said manual, so that we can be sure we're all talking about the same boiler?
    • Thanks Thanks x 1
  6. The Novice
    The Novice
    26 Sep 2019
    720
    Thanks Received:
    174
    North
    Country:
    What thermostat is it?
  7. MazaB
    MazaB
    Monday
    6
    Thanks Received:
    Country:
  8. MazaB
    MazaB
    Monday
    6
    Thanks Received:
    Country:
  9. The Novice
    The Novice
    26 Sep 2019
    720
    Thanks Received:
    174
    North
    Country:
    What happens if you add more pressure, does the gauge move? If not there could be a small blockage. I take it the Drayton didn’t make it work?
    • Thanks Thanks x 1
  10. MazaB
    MazaB
    Monday
    6
    Thanks Received:
    Country:
    Pressure rises if we add more. When I was clearing the air from the radiator you could feel the hot water coming up through the pipes at the bottom of the radiator.
    The Drayton didn’t do anything although I have seen online there has been difficulties wiring it. There is a black wire & a red wire.
Loading...
Share This Page
