No heating or hot water,
2 Aug 2009
Yorkshire
hi all
Just had bathroom fitter in whilst i've been away. and he's moved my radiator pipework and then finished for the day
We have an s-plan, 2 port system and are getting no hot water or heat.
I've loosened off the pump screw, a little water dribbled out but thats it.
any ideas?
is the pump running when heat called for ?
does the boiler fire up ?
is the header tank full ?
need more info.
does the boiler only run for a few mins then cut out ?
is the pipe on bothsides of the pump hot ?
greenstar cuttin in/out, pipes are warm on either side but not hot.
everytime I open up the pump a little air comes out
the systems airlocked.
bleed the pump with the system not running.
have you any bleed points around the cylinder pipework useally
on top of a vertical pipe at the highest point.
if you have bled the pump try putting it on top speed and that can force the air round.
shut the by-pass off temporarily while you shift the air with the advice already given.
Paul
Turn the pump speed to maximum for a while to help to shift the air.
See if there are any thumb air vents or auto vents with the screw closed.
I do think that anyone who moves rads etc. has a duty to sort out these minor problems before going home. Why do people employ them?
You should have phoned him and demanded that he comes back to sort it out !
Tony
tel me about it agile.
i'm bleeding the air vent next to the cylinder every 3 minutes. there is air escaping from it.
and the boiler keeps cutting in/out
A BG engineer has to post on a plumbing diy forum seeking advice. :eek: Goes to show the numpties ****ish gas employ nowadays doesn't it?
Any decent engineer would've fitted his own bathroom too. :LOL: Or did you want the job done properly not trusting your own handywork. . . .
Just goes to show you really are a muppet mr lsx. :LOL:
Tony
Here Here!!
Although this could have happened after he commisoned the sytem, however pretty unlikely. Lazy plumber I say
