No hot water but boiler seems fine (unvented cylinder)
15 Dec 2008
London
Any ideas appreciated!
My taps don't seem to have hot water any more (sort of tepid). I have a system boiler in the kitchen, an Oso unvented cylinder in a storage cupboard and underfloor heating.
When I turn on the UFH, the boiler kicks in.
I have a salus EP101 control thermostat never the UFH, never touched it since it was set up 10 years ago. Appears to be working fine.
The attached photo shows:
1. Out of shot, a fuse/isolation switch. Switched on, but the light is always off now.
2. A Honeywell box that connects to 3.
3. A Danfoss HPA2 actuator. I think this MAY have been replaced 3 or so years ago. I can push the lever from right to left (with resistance), but it doesn't seem to move on it's own when I turn the UFH off.
Any ideas where the problem might lie?!
Get the unvented cylinder serviced and ask them to investigate the fault. Could be motorised valve, could be on the unvented setup
If the pilot light on the fuse/isolation switch is now "always off" are you sure it's still supplying power? Could the fuse in it be blown?
Hmmm, that's a good point. If the boiler is working and the Salus control thermostat also, they should be talking to it. Changing the fuse is a cheap fix, and if it doesn't work I'll just have to get an engineer out as countryfan suggests. Thanks for the suggestion.
Switch and the interior.
No fuse with that switch to replace. Looks like thermal damage at the top though
The black "soot" above I guess?
Forgive me so that likely means the entire switch module needs replacing? And, if so, is it an easy thing to find and replace or best get a professional in? (My capabilities are limited, I won't pretend otherwise )
Correct, not soot, just possible arcing
Not necessarily needs replacing but may point towards a loose connection, often the neutral
